Getting Started with SuretyDIY and Interlogix Simon XTi: A Comprehensive Guide
Getting started with a DIY alarm monitoring system can be a bit overwhelming, but with SuretyDIY and the Interlogix Simon XTi, it’s a smooth process. Here’s a step-by-step guide to help you transition from another provider to SuretyDIY, ensuring your system is up and running efficiently.
Step 1: Choose the Right Service Plan
Before diving in, consider your needs:
  • Central Station Monitoring: Do you want 24/7 monitoring?
  • Z-Wave Automation: Do you have smart devices like door locks, lights, or thermostats?
  • Cloud Video: Are you using Alarm.com cameras?
  • Image Sensors: Do you have or plan to add these?
Step 2: Check Your Communications Module
If you’re using a Simon XTi system, locate your communications module number. Unsure how? This video can help. Once you have it, check if your module is unlocked using this tool.
Step 3: Upgrade to a 3G Module
If your module is 2G, it’s outdated. Upgrade to a 3G module for compatibility. SuretyDIY ensures your module stays unlocked, so no worries about getting locked out.
Step 4: Select Your Service Package
Choose between the Gold Interactive or Basic Interactive plans. Both include 24/7 monitoring, so pick based on your additional needs.
Step 5: Activate Your Service
After placing your order, follow the instructions in your welcome email to set up your account. Need help? Check out our video tutorials for the Simon XTi, including how to reset installer settings or run a cellular test.
Bonus Tip: Sensor Compatibility
The Simon XTi works with GE wireless sensors (319.5Mhz), so you can easily integrate them into your system.
If you have any questions or run into issues, don’t hesitate to reach out to customer service or visit our forum. Happy monitoring!
