I’ve recently had the pleasure of setting up my Glide Lights Controller with the 8pc kit, and I must say, it’s been a fantastic experience!
I wanted to share my journey in case anyone else is looking to set up something similar or is facing the same challenges.
Initially, I was a bit puzzled because I only received one controller with the 8pc kit. I wanted to set up two pieces at each corner of my TV, but it seemed like I’d need an additional controller to make it work. After some research, I discovered that you can actually pair multiple controllers with the same setup, which was a huge relief! ![]()
Setting Up the Glide Lights
I decided to place two lights at each corner of my TV, creating a stunning visual effect. The setup was straightforward thanks to the intuitive mobile app that comes with Glide. I was able to customize the colors and brightness levels to match my room’s ambiance perfectly. The app also allows for scene customization, which I’ve been using to switch between different lighting modes depending on the time of day or the activity I’m engaged in.
A Little Challenge & Solution
As I mentioned earlier, the single controller was a bit of a hurdle at first. I reached out to Glide’s customer support, and they were incredibly helpful. They guided me through the process of pairing an additional controller, which I purchased separately. Once I had both controllers set up, the system worked seamlessly! ![]()
My Experience So Far
The Glide Lights have completely transformed my living room. The RGBIC color range is vibrant and versatile, making it easy to create any mood I want. Whether it’s a relaxing evening at home or a lively movie night, these lights adapt perfectly.
One feature I particularly love is the voice control integration with Alexa. It’s incredibly convenient to adjust the lights without having to fiddle with the app. Simply saying, “Hey Alexa, turn on the movie mode,” does the trick! ![]()
Tips for Anyone Considering Glide Lights
If you’re thinking about getting Glide Lights, here are a few tips from my experience:
- Start small: If you’re new to smart lighting, start with a smaller kit and expand as you become more comfortable.
- Experiment with scenes: Don’t be afraid to create your own scenes and customize them to fit your lifestyle.
- Pair multiple controllers: If you want a more elaborate setup, consider pairing multiple controllers for greater flexibility.
Overall, I’m thrilled with my Glide Lights setup and would highly recommend it to anyone looking to enhance their home’s ambiance with smart lighting.
If you have any questions or need advice, feel free to reach out! Happy lighting! ![]()
