GoControl Thermostat Workaround and Tips
Hi everyone, I wanted to share my experience with the GoControl thermostats and Vera Edge. While I initially faced some challenges with the integration, I found a workaround that works well for me. Here’s my story:After setting up my Vera Edge, I purchased two GoControl thermostats, hoping for seamless integration. However, I encountered issues with setting temperature points and the ‘away’ mode directly through Vera. After some research and troubleshooting, I discovered a reliable method to control the thermostats manually while maintaining some automation.**My Solution:**1. Manual Control: I found that using the thermostat’s keypad works perfectly for setting temperatures and modes. While it’s not fully automated, it’s a practical workaround.2. Scene Automation: I created scenes in Vera that adjust the thermostat settings through the keypad. For example, a ‘Away Mode’ scene triggers a routine where the thermostat is manually set to ‘Away’ and the temperature adjusted. This isn’t perfect, but it’s functional.Tips for Others:- Check Compatibility: Always verify product compatibility before purchasing. While the thermostats were listed as ‘Works with Vera,’ the integration wasn’t as smooth as expected.- Explore Workarounds: If you face similar issues, consider creating manual routines or using third-party apps that might offer better integration.- Tech Support: Be patient with tech support. While their response time can be slow, persistence often leads to solutions.I’m currently looking into alternative thermostats that offer better Vera integration. If anyone has recommendations or success stories, I’d love to hear them!Stay warm and happy automating! :star2:
