I have connected the Cube to Home Assistant and added some automations - lights on/off, toggle a variable for dis-/enabling the doorbell. But because of the ‘fun factor’ of the cube - it is like a fidget - not always the best way to use…
I have seen the video from simon42, but are there some more fun/good usages of the cube?
@aqara_reg It’s fantastic to hear that you’re exploring the fun and functional aspects of the Aqara Cube with your Home Assistant setup! The Cube indeed offers a playful interaction with smart home devices. Based on the reference information, here are some additional fun and practical ways you could consider using your Aqara Cube:
Action and Scene Modes: The Cube can switch between action and scene modes. In action mode, you can control devices by flipping, shaking, or rotating the Cube. Scene mode allows each side of the Cube to control different scenes or devices, which can be especially handy for HomeKit users.
Rotating to Dim Lights: You can configure the Cube to adjust the brightness or color temperature of compatible Aqara lights by rotating it. This can add a tactile and intuitive way to manage your lighting ambiance.
10 Actions in Scene Mode: The Cube T1 Pro offers ten different actions in scene mode, allowing you to control various devices or scenes. Each side has clear dice-like indicators, making it easy to remember what each side does.
All-Round Compatibility: Beyond Home Assistant, the Cube is compatible with HomeKit, Alexa, and IFTTT, giving you more integration possibilities.
Feel free to experiment with these features to discover what works best for your home setup. If you have more ideas or need further assistance, sharing them here could inspire others and lead to more creative uses!
@aqara_reg It’s great to hear you’re enjoying the “fun factor” of the Cube—its interactive design really does make smart home control more engaging! From the automation recommendations and Cube specifications, here are some additional fun/good usages you might try:
- Adjust light color temperature or brightness: Rotating the Cube on a plane can tweak the color temperature or brightness of Aqara bulbs, ceiling lights, or LED strips, adding a dynamic touch to your lighting setup .
- Control curtains: Shaking, rotating, or flipping the Cube can open, close, or adjust curtains to your desired ratio (works with roller shade controllers or curtain drivers) .
- Diverse device control: Beyond lights, the Cube can trigger other actions like turning smart plugs on/off (flip 90°), controlling wall switches (flip 180°), or activating night lights (shake)—leveraging its gyroscope for direction-agnostic fun .
Have you tried any of these, or do you have other creative ideas? It’d be fun to hear how you might expand your automations!
If you’re looking for even more inspiration, the community often shares unique setups—feel free to keep the discussion going!
@aqara_reg It’s great to hear you’re exploring the fun side of the Aqara Cube—its fidget-like nature does make it a versatile tool! Here are some additional usages based on Aqara’s automation recommendations and Cube capabilities:
- Curtain control: Shake, rotate, or flip the Cube to open, close, or adjust curtains to a desired ratio (works with Roller Shade Controller or Curtain Driver E1) .
- Light adjustments: Rotate the Cube to tweak color temperature or brightness of bulbs, ceiling lights, or LED strips .
- Device-specific controls: Flip 90° to turn smart plugs on/off, flip 180° to control wall switches, or shake to activate night lights on the Control Hub .
These actions leverage the Cube’s gyroscope sensor, which works in any direction, so you don’t have to worry about orientation . Have you tried combining multiple actions (like a flip followed by a rotate) for more complex scenes? Would love to hear what you end up creating!
@aqara_reg It’s great to hear you’re exploring the “fun factor” of the Aqara Cube—its versatility really shines when you tap into different actions! Here are some additional usages from official automation recommendations and FAQs that might spark new ideas:
- Adjust light settings: Rotating the cube on a plane can adjust the color temperature or brightness of Aqara bulbs, ceiling lights, or LED strips (e.g., Aqara Bulb, Ceiling Light, LED Light Strip). This adds a tactile way to fine-tune your lighting ambiance [“content_id”: 0, “content_id”: 1].
- Control curtains: Shaking, rotating, or flipping the cube can open/close curtains or set them to a specific ratio, paired with Aqara Roller Shade Controller or Curtain Driver E1 .
- Trigger device-specific actions: Flip 90° to turn smart plugs on/off, flip 180° to control wall switches, or shake to activate the night light on the Control Hub. The cube can control most smart devices that work with the Aqara app .
- Custom scenes with unique actions: Try taping twice, pushing, or using “side X up” (via scene mode) to trigger personalized scenes—like setting a “movie night” mode (dimming lights + closing curtains) or a “morning” mode (opening curtains + turning on the coffee maker) [“content_id”: 5, “content_id”: 8].
These uses leverage the cube’s gyroscope sensor, so placing it on a flat surface (avoiding soft surfaces like sofas) helps ensure sensitivity .
Have you tried any of these, or do you have other creative ideas? The community would love to hear—sharing your experiments might inspire others too!
If you run into specific setup questions, feel free to ask, and we can troubleshoot together.
