Govee Bulbs with Motion Sensor Success Story
I’ve been trying to get my Govee bulbs to work with a motion sensor, and I’m thrilled to share that I finally cracked it! :tada: Here’s how I did it and some tips for anyone else looking to set this up.The Setup: I have a few Govee H6003 bulbs and a Wyze motion sensor. My goal was to have the lights turn on when motion is detected and stay on for a short while before turning off automatically.The Challenge: At first, I was struggling with the integration. The bulbs were connected to my Wi-Fi, and the motion sensor was set up, but they just wouldn’t work together. I tried a few different apps and settings, but nothing seemed to click.The Solution: After some research, I discovered that using a smart home app like Home Assistant or Alexa was the key. Here’s a step-by-step breakdown of what worked for me:1. Connect Your Devices: Make sure both your Govee bulbs and motion sensor are connected to the same Wi-Fi network. This is crucial for them to communicate.2. Choose a Smart App: I decided to go with Home Assistant because it’s highly customizable. You can also use Alexa or Google Home if you prefer.3. Set Up the Automation: - In Home Assistant, go to the automation section. - Create a new automation that triggers when the motion sensor detects movement. - Set the action to turn on the Govee bulbs. - Add a delay (I set it to 30 seconds) before turning the lights off again.4. Test It Out: Walk in front of the motion sensor to test. The lights should turn on, stay on for the set duration, and then turn off automatically.Tips for Success: - Placement Matters: Make sure your motion sensor is positioned correctly. It should cover the area you want to monitor without picking up unwanted movements (like pets or passing cars).- Adjust the Delay: Experiment with the delay time to find what works best for your space. I found 30 seconds to be perfect for my hallway.- Use a Reliable App: Stick with well-supported apps like Home Assistant, Alexa, or Google Home. They have robust automation features and community support if you run into issues.The Result: Now, whenever I walk into my hallway, the lights automatically turn on, giving me a nice surprise. It’s such a small thing, but it really adds to the convenience of my home. Plus, it feels great to have solved the puzzle!If you’re looking to set up something similar, I hope this guide helps. Let me know if you have any questions or if you’ve found a better setup—I’m always looking to learn more! :rocket::sparkles:
