I recently received my Govee Ceiling Light, and I must say, the setup was straightforward and the design is sleek. Adding it to the Govee app was a breeze, and I was impressed by the range of customization options available. However, when I tried integrating it with Alexa, I ran into a bit of a hiccup. Initially, Alexa couldn’t recognize the device, and I had to go through a few troubleshooting steps to get everything working smoothly. Here’s what worked for me:
- Unplug and Reset: I unplugged the ceiling light, waited for about 15 minutes, and then plugged it back in. This gave it a fresh start.
- Re-sync with Govee App: I made sure the device was properly paired with the Govee app before attempting any Alexa integration.
- Alexa Discovery: After ensuring the device was fully powered on and connected to my Wi-Fi, I went into Alexa’s settings and chose the option to discover new devices. This process took a bit longer than usual, but eventually, Alexa detected the ceiling light.
- Testing Commands: Once paired, I tested various voice commands, and everything worked perfectly. I can now control the brightness, color, and even preset scenes using Alexa.
For anyone else experiencing issues with Alexa integration, I recommend double-checking your Wi-Fi settings and ensuring the device is fully powered on before starting the discovery process. It’s also worth noting that patience is key during this troubleshooting phase.
I’m really happy with how this setup turned out. The Govee Ceiling Light adds a modern touch to my living space, and the integration with Alexa makes controlling it incredibly convenient. If you’re considering adding a smart ceiling light to your home, I highly recommend giving Govee a try!
