Govee Firmware Update Experience and Tips
I recently went through a firmware update process for my Govee backlight 3, and I wanted to share my experience and some tips for anyone else going through this.
First, I noticed that my device needed an update, but it was a bit frustrating because the app couldn’t consistently detect it. After a few attempts, I realized that sometimes the app might not recognize the device if it’s in a low-power state. My tip here is to ensure your device is fully charged or plugged in before starting the update process.
Once the update started, I was surprised at how seamless it was. The device restarted on its own, and within a few minutes, it was back up and running. I noticed a slight improvement in the backlight’s responsiveness, which was a nice touch.
However, I did run into an issue where the app couldn’t detect the device again after the update. After some research, I found that resetting the device via the app’s settings helped. It’s a bit of a hassle, but it’s a reliable fix.
If you’re hesitant about updating multiple devices at once, like I was, I recommend starting with one device to test the waters. If everything goes smoothly, you can proceed with the others. It’s a safer approach, especially if you’re not sure how your devices will react to the update.
Overall, while the process had its bumps, the end result was worth it. My Govee backlight 3 feels more responsive and reliable now. If you’re considering an update, don’t hesitate—just make sure to follow these tips to make the process as smooth as possible!
#Govee #FirmwareUpdate #SmartHomeTips
