Govee Outdoor Lights Brightness Adjustment Guide
Govee Outdoor Lights 2pk are a fantastic addition to any home, offering bright and crisp lighting to enhance safety and curb appeal. However, if you’re finding the lights too bright, especially at night, there are a few adjustments you can make to ensure they meet your needs without causing discomfort.
  1. Adjust Brightness Settings:
    • Open the Govee app on your smartphone.
    • Navigate to the device section where your outdoor lights are listed.
    • Look for a brightness slider or settings icon and adjust the light intensity to a comfortable level.
  2. Modify Installation Position:
    • Consider repositioning the lights to avoid direct glare into windows or sensitive areas.
    • Adjust the angle of the lights to direct the beam downwards, focusing on the ground rather than upwards.
  3. Use Accessories:
    • Install遮光罩 or diffusers to soften the light output.
    • Ensure the lights are mounted at an appropriate height to prevent excessive brightness in unintended areas.
  4. Automation Settings:
    • Set up schedules in the Govee app to have the lights turn on at dusk and off at dawn.
    • Use motion sensors or light intensity sensors to control the lights automatically, ensuring they only activate when needed.
  5. Contact Support:
    • If adjustments don’t resolve the issue, reach out to Govee customer support for further assistance.
By making these adjustments, you can enjoy the benefits of your Govee Outdoor Lights while maintaining a comfortable and balanced lighting environment around your home.
