Govee RGBIC LED Strip Application Tips
Hey everyone, I’ve been experimenting with my new Govee RGBIC LED strips and wanted to share some tips on how to apply them without damaging your furniture or walls. I recently installed a set in my entertainment center, and while the sticky backing worked well initially, I was worried about removing them later without ruining the finish.
First, I tried using the sticky tape as instructed, but when I had to take them down, it left some residue and even lifted a bit of the paint. To avoid this, I looked into alternative methods. I found that using 3M adhesive strips or command hooks was a much safer option. These allow you to mount the strips securely without damaging the surface. Plus, they’re easy to remove later if I want to reposition them or take them down entirely.
Another tip I came across was using silicone adhesive dots. They provide a strong hold without the risk of peeling off paint or leaving sticky residue. I’ve also seen some creative solutions where people use small clamps or clips to attach the strips to edges or corners without needing any adhesive at all.
If you’re planning to apply these strips on a wall, I recommend using a stud finder to ensure you’re attaching them to a solid surface. This not only makes the installation more secure but also prevents any potential damage to the wall.
Overall, while the sticky backing is convenient, it’s worth considering these alternative methods for a cleaner, safer installation. I hope these tips help someone else avoid the same issues I faced! Let me know if you have any other tricks or solutions.
