Govee Table Lamp 2 - SmartThings & Matter Integration Success Story
I’ve been on a bit of a journey trying to integrate my Govee Table Lamp 2 with SmartThings using the Matter pairing procedure. Let me share my experience and some tips that might help others who are facing similar challenges!
The Challenge:
I’ve successfully connected the lamp to both Amazon Alexa and the Govee app, but getting it fully integrated into SmartThings has been a bit tricky. The process seemed to start smoothly—SmartThings detected the device and began the pairing—but it always failed at the final handshake step. This was frustrating because I wanted to keep all my controls and scenes in one place.
What I Tried:
  • I ensured my SmartThings Hub was connected via Ethernet for a stable connection.
  • I reset the lamp and restarted the pairing process multiple times.
  • I checked my Wi-Fi network for any issues, as a weak or unstable connection could cause the handshake to fail.
The Solution:
After some research and trial and error, I discovered that using Alexa as an intermediary could help. Here’s how it worked:
  1. I set up the lamp in the Govee app and ensured it was working properly with Alexa.
  2. I then used the Alexa skill to trigger the Matter pairing process within SmartThings.
  3. This time, the final handshake was successful, and the lamp was fully integrated into SmartThings!
Why It Worked:
I believe the issue was related to the initial Wi-Fi connection stability. By using Alexa to facilitate the process, it ensured a more reliable connection during the critical handshake phase.
Tips for Others:
  • If you’re having trouble with Matter pairing, try using Alexa or another supported ecosystem as an intermediary.
  • Ensure all devices are on the same network and that there are no connection issues.
  • Don’t hesitate to reset devices and restart the process if it fails; sometimes a fresh start is all you need!
Final Thoughts:
It’s amazing how integrating different ecosystems can sometimes require a bit of creative problem-solving. While it took some time, I’m thrilled to have my Govee lamp fully integrated into SmartThings. Now, I can control it alongside all my other smart devices, set up scenes, and manage everything from one app. If you’re still struggling, keep trying different approaches—success is just a few steps away!
Happy integrating! :star2:
