Hey everyone! I wanted to share my recent experience with the Govee Wall Sconce and how I integrated it into my smart home setup. It’s been a bit of a journey, but I’m thrilled with the results!
The Setup
I recently purchased the Govee Wall Sconce and decided to install it in my living room. The installation itself was straightforward, but I did run into a minor hiccup. The sconce is heavier than I initially expected, so I had to adjust my mounting plan to ensure it was secure. I ended up using the included screws and followed the instructions carefully. It’s now a beautiful centerpiece in my room!
Automation Fun
I wanted to take it a step further by integrating it with my Home Assistant setup. I created a simple automation that turns the sconce on when I enter the room and adjusts the brightness based on the time of day. Here’s a quick breakdown of how I did it:
- Motion Sensor Detection: I used a motion sensor to detect when I enter the room.
- Time-Based Brightness: I set the sconce to dim in the evenings and brighten during the day using a built-in schedule.
- Color Customization: I programmed it to shift to warmer tones in the evenings for a cozy ambiance.
Tips for Others
If you’re considering this sconce, here are a few tips:
- Mounting: Make sure to use the provided screws and follow the instructions. It’s heavier than it looks!
- Automation: Don’t hesitate to experiment with different automation rules. The possibilities are endless!
- Compatibility: It works seamlessly with most smart home systems, so integration shouldn’t be an issue.
Overall, I’m absolutely satisfied with the Govee Wall Sconce. It’s not just a light; it’s a statement piece that enhances my home’s aesthetic and functionality. The integration with my smart home setup has made my evenings even more enjoyable. If you’re on the fence about getting one, I highly recommend it!
Happy smart home tinkering! ![]()
