Grafana Crashing on Raspberry Pi
Hey everyone, I’m encountering an issue with Grafana crashing every two minutes on my Raspberry Pi after migrating from OpenHAB 2 to 4. I followed the openHABian setup for Grafana and InfluxDB, but it’s not working as expected. Here’s what I’m experiencing and what I’ve tried so far:
The Problem
  • Crashing Intervals: Grafana crashes approximately every two minutes. The logs indicate a SIGILL error, which suggests an illegal instruction might be causing the crash. This could be related to the ARM architecture or a corrupted installation.
  • Memory Issues: The system logs show that the /var/log directory is filling up due to the crashes, which might be contributing to the instability.
What I’ve Tried
  1. Checked Grafana Version: I ensured that I’m running the latest stable version of Grafana for ARM devices. However, the issue persists.
  2. Adjusted Logging Settings: I reduced the logging level to minimize log file growth, but this hasn’t resolved the crashing issue.
  3. Reinstalled Grafana and InfluxDB: I performed a clean reinstall, but the problem remains.
  4. Monitored System Resources: I observed that CPU and memory usage spike before a crash, suggesting potential resource constraints.
Possible Solutions
  1. Alternative Visualization Tools: If Grafana continues to be problematic, I might consider switching to a different visualization tool that’s more stable on Raspberry Pi, such as Prometheus with a different frontend.
  2. Optimize Logging: Further adjust logging settings to prevent disk space exhaustion, though this won’t fix the root cause.
  3. Hardware Upgrade: If resource constraints are the issue, upgrading to a more powerful Raspberry Pi model might help.
  4. Community Support: I’ll reach out to the Grafana community for insights or known issues with ARM devices.
Request for Assistance
If anyone has experienced similar issues or has suggestions for troubleshooting or resolving this, I’d greatly appreciate your input. Let’s work together to get Grafana running smoothly!
Thanks in advance for your help!
