Hello everyone, I wanted to share my recent success in integrating my Grainfather with Home Assistant using ESPHome and an ESP32 board. This journey was both challenging and rewarding, and I hope my experience can inspire others to explore similar setups. My Setup: I’ve always been passionate about homebrewing, and the Grainfather Connect has been an essential tool in my brewing process. However, I wanted to take it a step further by integrating it into my smart home ecosystem. After some research, I discovered that ESPHome could bridge the gap between the Grainfather’s Bluetooth functionality and Home Assistant. The Process: The first step was to set up an ESP32 board with ESPHome. I configured it to connect to the Grainfather via Bluetooth and then integrated it into my Home Assistant setup. This involved a bit of trial and error, especially with the Bluetooth pairing process, but I eventually got it working smoothly. Challenges and Solutions: One of the main challenges was ensuring stable Bluetooth connectivity. I found that placing the ESP32 in a central location within my brewing area significantly improved reliability. Additionally, I had to tweak the configuration files to ensure data was being accurately transferred to Home Assistant. Final Thoughts: The end result is fantastic! I can now monitor and control my Grainfather directly from my Home Assistant dashboard. It’s incredibly satisfying to see my brewing process integrated seamlessly into my smart home setup. If anyone is interested in doing something similar, I’d be happy to share my configuration files and troubleshoot any issues you might encounter. Cheers to all the fellow homebrewers and smart home enthusiasts out there! ![]()
