H2 - 2ch but only a single light
Hi, I have a combined light and fan which I can control independently within Home Assistant but I’m wondering if I purchase an H2 2 channel switch could I set up switch 1 as the primary control for the light with a wireless switch to control brightness then have the the second relay switch as a pure wireless switch to control the fan without having to connect it to a L1 live feed?
Hello @andrew_sanderson
I think this can be done if you unlink the keys from the relay and set up automation in home assistant, but then your fan will be connected directly and if it is there (added to HA), then you can turn it on/off.
