H2 Switch stops responding
All of a sudden my H2 Switch (EU) stopped responding. Is there any way to revive it?
Hi @aqara236 can you give us more infos?
Perhaps, if you don’t have a reset only in the hub, someone turned it on and off several times and disconnected it from the hub to reconnect.
can you resert the switch? or is the Hardware not responding?
I had one swapped out by Aqara as the relay stopped working. It still worked as a virtual switch, but the relay had failed. It was only the top left though, the right still worked.
Thanks for your feedback. I resetted the switched by a power cycle. It is now functioning again.
