HDMI CEC Issues and MyQ Device Connection Troubleshooting
Hello everyone, I hope this post finds you well. I’ve been diving into some technical challenges with my home automation setup and thought I’d share my experiences in case others are facing similar issues. Let’s start with my HDMI CEC problem. I’ve been getting an ImportError related to the ‘cec’ module, which has been quite puzzling. After some research, I realized the issue might be with the symlink step, as the error message indicated that the module already existed. I tried removing the existing symlink and recreating it, but the problem persists. I’m wondering if there’s a specific version of the pycec library that’s compatible with my setup or if I need to adjust my Python environment. If anyone has encountered this before, I’d love to hear how you resolved it.
Moving on to my MyQ garage door opener. I’ve successfully installed the MyQ binding in OpenHAB, and the bridge seems to be online, but the garage door and light are showing as UNKNOWN. I’ve double-checked the serial numbers and credentials, so I’m not sure where the disconnect is happening. It’s frustrating because the devices are physically connected and functioning, but the integration isn’t working as expected. I’m considering reaching out to Fibaro support or checking if there are any firmware updates that might resolve this. If anyone has successfully integrated MyQ devices, I’d appreciate any tips or troubleshooting steps you’ve found useful.
Another issue I’ve been juggling is with my Fibaro dimmers. They’ve been flickering, which has been a bit of a nuisance. I came across a suggestion to create a custom device type with specific parameters to adjust impulse lengths and switch settings. I’m not a programmer, so this feels a bit daunting, but I’m determined to figure it out. I’ve reached out to the community for help with the code, and I’m hopeful someone will be able to assist. In the meantime, I’m exploring alternative configurations or workarounds to stabilize the dimmers.
On a more positive note, I’ve managed to set up a virtual thermostat linked to my temperature sensor, which has been a great addition to my heating system. It’s amazing how such a simple integration can enhance comfort and efficiency. I’m also experimenting with automations to control my garage door opener and lights, aiming to create a seamless experience. It’s been a mix of challenges and triumphs, but each problem solved brings me closer to my goal of a fully integrated smart home.
I’d love to hear from others who’ve tackled similar issues or have advice on these topics. Let’s keep the conversation going and help each other overcome these hurdles!
