Heater controller
I’ve seen there’s the smart radiator thermostat. Is there an Aqara controller for the heater, so the thermostat can send a signal to start heating?
If not, is there a plan to release one?
If you have an on/off central heating boiler then you can write an automation which switches an aqara relay on or off
Hello, I have been using such a system since 2020.
Methods for controlling room temperature using Aqara devices the moment, you can use the W500 using an additional 220 volt relay for dry contacts for the boiler.
