HELP: Aqara E1 hub + P1 sensor
Hi all, I have an Aqara E1 hub paired with some P1 motion sensors… when motion is triggered and after sunset = lights on.
When I initially installed this setup I had no issues whatsoever everything worked fine.
However I now have approx 7s delay around the same time every day (approx 4pm-9pm) outside of this time I have 0 delays to the lights coming on. Please can someone help??
I heard there are problems with automations run by the cloud during the day, I saw this issue mentioned on reddit. Unfortunately, the only workaround is buying a hub that can run those automations locally (eg. G3 camera hub, M3 or some other newer hub).
