[Help needed] How much clearance is needed above the deadbolt centre for the Aqara U400?
Hi everyone,
I’m considering installing an Aqara U400, but I have a pull handle above my existing deadbolt and want to make sure there is enough clearance.
Does anyone know the minimum clearance required above the deadbolt centre for the U400?
If anyone has a U400 installed and could measure the distance from the centre of the deadbolt to the top of the exterior unit , that would be really helpful.
Thank you
@GrinGuru Hi there! Thanks for reaching out with this important question. Getting the clearance right is crucial, especially when you have a pull handle above the deadbolt.
Based on the technical specifications for the Aqara Smart Door Lock U300, which shares similar dimensional constraints with the U400 series, the distance from the center of the fingerprint part (which aligns with the deadbolt center) to the top of the panel is 102mm. This measurement is key to ensuring you have enough space for the exterior unit to fit without interfering with your existing hardware.
It’s always a good idea to double-check the specific U400 installation guide or consult with a professional installer if your door setup is particularly unique, as door thicknesses and latch types can vary.
If you need more detailed installation support, please feel free to contact the Aqara Home App Customer Service Team (Profile> Help & Feedback > Customer Service) or scan the QR code:
Happy to help if you have any other questions
Hi @GrinGuru
On the outside of the door, the lock body is 12cm above the center of the deadbolt.
On the inside of the door, the lock body is 14cm above the center of the deadbolt.
I snapped a couple of pictures for you. (It looks like the tape is too high but that’s just parallax):
Thank you very much for taking the time to measure this and share the photos @starlitter :pray:
Unfortunately, it looks like the U400 might not work with my setup. I’d better look for something a bit smaller.
