Hello, all.
I am doing a renovation in Europe and installing Aqara switch H2 EU throughout the apartment. All will be in Zigbee mode as I have an M3 hub.
I will be using an LED strip as a primary light source, so I cannot use the standard Aqara LED T1 kit. It seems that the Aqara ZNDDODO12LM is a 120W driver but it’s unclear if it will only work with my region set to China or if the European market can add it as well.
Link to seller on Ali Express:
https://www.aliexpress.us/item/3256810055318819.html
I do also have an HA Green hub and I see that z2mqtt could handle the device:
If I have to choose between:
- Aqara driver via z2mqtt on HA Green
- Matter LED controller bound to M3 hub
… which would be the way to go? I see posts about the Matter LED controllers working fine with the M3 hub, so I assume it may work just fine too.
Thank you!
