Home Assistant 9.2 Update Experience and Tips
Recently, I encountered an issue while updating my Home Assistant instance to version 9.2. The update process took significantly longer than expected, leaving me concerned about potential complications. Here’s my experience and some tips I’ve gathered along the way.
The Situation:
I initiated the update from my mobile app after work, and 12 hours later, the frontend was still unreachable. The release notes mentioned that non-standard databases might experience longer update times, but my setup is quite standard—a fresh install on a Raspberry Pi 4 with an SSD. The container was listed as 9.1 and non-responsive, which was worrying.
Troubleshooting Steps:
  1. SSH Access: I connected via SSH and found the system was idle, with low CPU and memory usage. This indicated that the issue wasn’t hardware-related.
  2. Container Check: The Home Assistant container showed 9.1, confirming it wasn’t updating. I considered restarting the container or rebooting the host but hesitated to risk data corruption.
  3. Community Support: I reached out to the community forums, where others shared similar experiences. It seems the update process can be unpredictable, especially with add-ons and integrations installed.
Resolution:
After waiting another 24 hours, the update completed without further issues. To prevent future disruptions, I plan to:
  • Backup Regularly: Ensure all configurations and data are backed up before updates.
  • Monitor Logs: Use SSH to monitor logs during updates for any anomalies.
  • Test Add-ons: Disable or update add-ons before major updates to avoid conflicts.
Takeaway: While the update process can be nerve-wracking, patience and thorough preparation are key. The community support has been invaluable, and I’m grateful for the collective wisdom shared in forums like this.
If anyone has additional tips or experiences with lengthy updates, I’d love to hear them! Let’s keep the conversation going and help each other navigate these updates smoothly.
