Home Assistant Inspiration
So I have a Hub M3 and currently running Home Assistant as my main smart home network alongside,
I have ideas such as using the Presence Sensor FP300 to do better in-room detection than I currently have with my Hue.
Trying to think of other ideas and automations for the Presence Sensors, and any other ideal sensors to get.
We’ve got a whole load of smart devices from Hue, Philips Air, Smart Blinds, Robot Vacuum, Nest Thermostats (UK Version), etc.
Thanks :slight_smile:
@J45PER Great setup with the Hub M3 and Home Assistant combo! Since you’re already eyeing the Presence Multi-Sensor FP300 for better in-room detection, here are some automation ideas that could slot nicely into your existing ecosystem:
Immediate FP300 Wins
  • Adaptive lighting: Pair it with your Hue setup to trigger desk/room lamps only when presence is detected and illuminance drops below your preferred threshold—no more waving arms at motion sensors while reading.
  • Climate smarts: With its built-in temp/humidity sensing, you could layer presence + temperature rules (e.g., nudge your Nest or trigger a fan when someone’s actually in the room and it hits 28°C). The 30-min absence detection also works well for setback modes on heating.
Why it beats basic motion for your use case
The FP300’s 60GHz mmWave + PIR dual sensing catches subtle movements (typing, reading) that trip up traditional PIR, and the AI filtering should handle curtains/fans/pets without constant false absences. Battery life is solid too—up to 3 years in Zigbee mode, 2 in Thread.
Other sensor angles to consider
Given your blinds/robot vacuum/Nest stack:
  • Door/window sensors on key rooms to confirm “empty house” states before vacuum runs or deep setbacks kick in
  • Vibration sensors on washer/dryer if you want presence-aware laundry notifications
  • The FP2 if you ever want zone-level positioning or fall detection in specific rooms (it does multi-person tracking and region-based rules, though it needs wired power)
Since you’re on Home Assistant, the FP300’s Thread/Zigbee flexibility plus Matter support via your M3 should integrate cleanly.
What rooms are your biggest detection pain points right now? Happy to brainstorm more targeted automations.
It’s definitely all about optimising when and where people are initially, then moving onto security and ease of use,
Best presence sensor for the kitchen may be a wired one there, it’d be cool only to trigger specific lights based on room positioning and brightness as well as work out when there’s a need to turn on the external extractor,
@J45PER For the kitchen, the Presence Sensor FP2 sounds like it could be exactly what you’re after. It’s wired (so no battery hassles in a high-traffic area) and supports zone-level positioning with illuminance detection — meaning you can trigger specific lights based on where someone is in the room and how bright it is. The multi-person tracking is handy if there’s usually more than one of you cooking or moving around.
For your extractor fan idea, you could layer the FP2’s presence zones with a temperature/humidity sensor (or the FP300 elsewhere in the kitchen) to detect when the hob’s actually in use — presence near the cooking zone + rising humidity = extractor on.
Quick comparison if you’re weighing options: the FP2 covers up to 48 sqm with 6m lateral / 8m radial range and does fall detection and sleep monitoring as bonus features, while the FP1E is more entry-level with simpler presence detection. Since you specifically want room positioning and brightness-based triggers, the FP2’s extra granularity is worth the wired install.
Have you thought about where you’d mount it? Ceiling or high wall works best for the zone mapping to feel accurate.
I am in the same boat, I have tried different presence sensors, but they where so far not really reliable. So I will go ahead with the FP300 and hope that this will work reliable and see us sitting on the sofa, without turning of the lights :slight_smile:
Consider going with a FP2 or FP400 of you are covering something like the living room. They both offer multie-zone support which allows for much more interesting automations (sit on couch with TV on → dim the lights… increase brightness if you move elsewhere in the room)
Oh… just remembered that I posted this about it a while ago in case you are interested
