After spending several weeks researching and planning, I finally decided to install Home Assistant (HA) 2025.8 on my Raspberry Pi 4. I’ve been using my Pi for various Python development projects, and I wanted to ensure that installing HA wouldn’t interfere with my existing setup. I also wanted to set up a Cloudflare Tunnel for remote access and a WireGuard VPN server, which made me wonder if using Docker with separate containers for HA and Cloudflare would be the best approach. I reached out to the community for advice, and the suggestions I received were incredibly helpful!
While setting up HA, I also came across an interesting issue with my new Wiz Smart Plug. Initially, the energy consumption readings weren’t working, but after removing and re-adding the device to the Wiz app, the firmware updated, and the power readings started showing up. However, the plug reports readings sporadically—sometimes 15-30 minutes out of date. This inconsistency is a bit frustrating, especially when monitoring power usage drops. I’m curious if anyone has found a way to adjust the sync frequency to ensure more live, accurate readings.
Another challenge I encountered was with my Raspberry Pi camera stream. I configured the camera using the rpi_camera platform, but the video feed was extremely slow. It seemed like the setup was only capturing still images instead of a live stream. After some research, I discovered that adjusting the image width and quality settings significantly improved the performance. This was a great learning experience, and I’m excited to explore more advanced camera integrations in the future.
Overall, my journey with Home Assistant has been both rewarding and enlightening. The community support has been phenomenal, and I’m looking forward to continuing my smart home projects. If anyone has tips for optimizing Docker setups or improving smart plug sync frequencies, I’d love to hear them!
