Hello everyone! I’ve been diving into the world of Home Assistant and smart home automation for the past few months, and I wanted to share some of my experiences and tips with you all. My journey started with a simple goal: to monitor the connectivity and performance of my local network devices. I’ve been using Home Assistant OS on a Proxmox KVM setup, and it’s been a fantastic experience so far. However, I hit a snag while trying to implement a custom ping sensor to track my network hosts. Let me walk you through my experience and some of the lessons I’ve learned along the way.
Initially, I set up a ping sensor using the built-in integration in Home Assistant. The default update interval was 30 seconds, which wasn’t fast enough for my needs. I disabled the default trigger and created my own using a time pattern trigger that fires once every minute. This setup works, but there’s a strange 10-second pause between updates that I can’t seem to explain. After some digging through the logs, I noticed that the warning about the update taking over 10 seconds only appears when the ping starts on the 0th second of the minute. This behavior is consistent across different configurations, and it’s throwing off my connectivity monitoring efforts.
I’ve tried adjusting the number of ping packets sent per run, but this doesn’t resolve the issue. Increasing the packet count to 57, for example, just extends the delay without solving the root problem. It seems like there’s an enforced cooldown or rate limit somewhere in the system, but I haven’t been able to find any documentation or forum posts that mention this behavior. I’m starting to wonder if this is a bug in the Home Assistant integration or if there’s something I’m missing in my configuration.
One workaround I’ve considered is writing a custom script to handle the ping monitoring and integrate it into Home Assistant. However, I was hoping to keep things simple and avoid the hassle of managing a separate daemon. If anyone has experienced a similar issue or has any insights into what might be causing this delay, I’d love to hear from you!
In the meantime, I’ve been exploring other ways to enhance my smart home setup. For example, I’ve been experimenting with custom dashboards and automation rules using the Home Assistant frontend. I recently set up a system to monitor my energy consumption using a Shelly energy meter, and it’s been incredibly helpful in identifying areas where I can reduce my usage. I’d love to hear about any creative ways others have used their smart home setups to save energy or streamline their daily routines.
Another project I’ve been working on is integrating my Govee smart lights into a more immersive home theater experience. By combining the lights with a custom music assistant card on my dashboard, I’ve been able to create a more engaging atmosphere for movie nights and music sessions. If anyone has tips or tricks for optimizing their Govee setups, I’d be happy to share and learn from your experiences!
Overall, my journey with Home Assistant has been both challenging and rewarding. It’s amazing to see how much control and customization you can achieve with the right setup, even if it requires a bit of trial and error along the way. I’m excited to continue exploring new features and integrations, and I look forward to hearing about your projects and experiences as well!
Best regards,
