HomeKit Aqara Integration
Hi all. I’d love to hear how others are integrating their Aqara products with Aqara. Are you using thread, the Aqara hubs, or other approaches? Also, probably another topic–but curious if anyone is using Open Claw or Hermes or other local AI type harnesses to control or interact with your smarthome.
@church_nathan Great question! For HomeKit integration specifically, the most common approach with Aqara is going through an Aqara Gateway using the HomeKit protocol. Once your gateway is connected to Apple Home, all your Zigbee child devices should automatically sync over—no separate HomeKit codes needed for each sensor or switch, the gateway handles all of that.
If you’re also exploring Home Assistant, any Aqara product with HomeKit support can be brought in directly via the HomeKit Controller integration. Just reset the device, make sure it’s on your local network, then pair it through Settings > Devices & Services in HA.
As for Thread—Aqara’s newer hubs and some devices are starting to support it, but the ecosystem still largely leans on Zigbee through their hubs for now.
Regarding Open Claw, Hermes, or other local AI harnesses—that’s a bit more niche and experimental. I’d love to hear if anyone in the community has actually gone down that path! Local voice/AI control is definitely an interesting space, though I don’t have solid reference info on those specific tools.
What devices are you working with currently? That might help narrow down the best integration path for your setup.
