Hey everyone, I’ve been struggling with getting my Homematic devices to connect properly to Home Assistant. Despite having a solid setup with a Raspberry Pi 3 running pyCCU 3 and all ports open, I couldn’t get any entities to show up. The logs indicated everything was fine, but in reality, nothing was working. I tried various configurations, including callbacks, but nothing seemed to make a difference. I was really stuck and frustrated, especially since these devices had worked before. After some research and trial and error, I discovered that the entities were actually there but disabled. Removing those disabled entities and restarting the server finally fixed the issue! It was a bit of a relief, but also a bit confusing why they were disabled in the first place. I guess it’s important to check for disabled entities if you’re having similar issues. Hopefully, this helps someone else who might be going through the same problem. ![]()
