Homematic Devices Integration and Automation Tips
As a new user of Homematic devices, I’ve had both successes and challenges in setting up my smart home system. One of my first projects was integrating HM-LC-Sw2-FM and HM-PB-2-WM55 in two separate rooms. In Room 1, I successfully paired the devices and controlled the lights without needing the CCU2. However, when I tried the same setup in Room 2 using CCU2 first, I couldn’t pair them directly afterward. After some research and experimentation, I found that unlearning the devices from CCU2 and then pairing them first before re-registering them solved the issue. This experience taught me the importance of understanding the setup order and device learning processes in Homematic systems. I’d love to hear others’ tips on optimizing device integration and automation!
