How do you verify child devices after a hub firmware update?
After a hub firmware update, I would check each device path separately before resetting or re-pairing anything. A short log can record the hub firmware version and online status; which Zigbee and Thread children are visible and when they were last seen; whether a simple command works and a sensor event appears; and whether a small automation fires on two consecutive tests. I would note the UTC time of each check and when the problem began.
If only one radio group fails, that gives a different clue from all children failing while the hub still streams video. Keeping those observations together should also make a support ticket easier to act on without losing the original pairing state.
What is the smallest check you use to decide a hub has fully recovered after an update?
Hello.question: is this some sort of advice?more why would you need to check something after and hub update?I never need to check nothing as if there is an device offline you should see it on Aqara home app but as I sad I never needed to check nothing because even after an update if an hub all devices were still connected
I dont see the need for myself to check all child devices after a Hub Update. For me it’s the hard path like when something goes offline I recognize by myself sooner or later. I see this is not the best way to handle that for really important devices but fortunately I didn’t had an issue with offline devices after an Update yet
Hmm, also didn’t get it, why to check all child devices after a hub update!
If the devices are Grey out in the accessory list, I will first restart the hub and check if they come back! That’s all
Fair point—I didn’t mean that every child device needs a full check after every routine update. If something changes or a critical automation matters, I’d test the affected path once before resetting or re-pairing; the online indicator alone doesn’t show whether that automation fired. If everything is working, there’s no reason to run through the whole list.
