How does the w600 work?
I don’t understand the smart schedule the manual and in the internet found manual do n ot explain it.
  1. You can create up to 7 events
    You can create up to 7 events of the same type on different times BUT when your save it it only allows it if you change the temperature for all events of the same type on all days to the same temperature? Which is weird
  2. The device is using the last temperature from the last available event! Even if the event is not on the same day? Why?
    My device switches itself on and heats to the temperature of the last event! Regardless how many days are between?
  3. Because of this? I can’t switch it off… every time it switches itself on after an …? Period of time?
    I mean I want to switch it off between 00:00 and 06:30 but that is not possible?
    How can it be that this no one figured out and this was shipped to customers?
Hello,
You have 5 modes that are named in the app as Home, Away, Wind Down, Sleep & Vacation.
Each mode can have a temperature set point.
The modes can then be added to the schedule for each day, but note the mode temperature set point is the same for each day. If you adjust the mode set point it will effect every day where the mode is used.
I would have preferred to have the ability to name the modes to something more preferable to myself.
The fact you are home does not mean you want to heat a room.
That’s what I already mentioned. But the behavior does not make sense for me…
