How have people made a standard up and over garage door smart?
Most of what I can find covers sectional doors, so I’m after some real world experience from anyone who’s done it on a bog standard UK up and over.
A few things I’m trying to work out:
  • If the door is currently manual, what opener did you fit first, and is there anything that plays nicer with Aqara kit than others?
  • Did you go with the Garage Door Controller T2 Kit, or wire up a Dual Relay T2 to the opener yourself? How did you find it?
  • How are you handling open/closed status? Is the sensor reliable on a door that swings out rather than rolling up?
  • Does it end up showing properly as a garage door in Apple Home, or does it land as a switch?
Photos of how you’ve mounted things would be very welcome. I’d rather learn from people who’ve already done it than guess.
Thanks in advance.
I have a new roller door with rf key fobs and a manual button inside the garage.
Was told by the installer that it’s not smart and he wasn’t sure if they do a smart wifi option.
Quick chat with AI and it was suggesting the T2 would wire in perfectly, just need to be sure to remove the jumper wire to make it low voltage.
I’ll add pics once the T2 arrives and let you know the brand of controller as I’m sure they are likely quite universal for controllers.
Just yours will be a chain mechanism for up and over where mine is like a blind roller.
