How I Achieved Seamless Morning Light Transitions with Philips Hue
Good morning everyone,
I wanted to share my experience and solution regarding a common issue many of us might face with Philips Hue lights, especially those ceiling-mounted ones. I’ve been using Hue lights for a while now, and I’ve always appreciated their versatility, especially the ability to adjust color temperatures. However, there was one aspect that was slightly annoying—waking up to a blue or vibrant color I had set the night before.
The Problem:
At night, I often change the color temperature to make the lights warmer for a cozy ambiance. Sometimes, I even set them to different colors for a fun vibe. But come morning, I’d often find myself waking up to a color that wasn’t ideal for starting the day. While it wasn’t a huge issue, it wasn’t the most pleasant way to begin my mornings.
The Solution:
After some research and experimentation, I found a way to automate this process. I discovered that using SmartThings along with a bit of creativity, I could set the lights to reset to their default white tone at a specific time—4 AM in my case. This ensures that by the time I wake up, the lights are at a neutral setting, making the transition from sleep to wakefulness smoother.
Here’s how I did it:
  1. Scheduled Reset: I created a routine in SmartThings that triggers at 4 AM every day. This routine changes the color temperature of my Hue lights back to their default white setting. The key here was ensuring that the lights remain off during this reset. I initially tried setting them to turn on briefly before turning off, but that didn’t work smoothly. Instead, I found that adjusting the color temperature directly without turning them on was the more seamless approach.
  2. Automation: While SmartThings didn’t support this directly at first, I explored other integrations and found that using WebCore with a bit of tweaking allowed me to set the color temperature without turning the lights on. It required some trial and error, but the end result was worth it.
  3. Testing and Adjustments: I tested the routine over a week, tweaking the timing slightly to ensure it didn’t interfere with my sleep. It’s been working perfectly ever since!
Why This Matters:
For those of us who value a consistent and pleasant morning routine, small details like the color of our lights can make a big difference. Automating this process not only saves time but also enhances the overall experience of waking up in a smart home environment.
I hope this tip helps someone out there who’s dealing with a similar issue. Let me know if you have any questions or if you’ve found other creative solutions to similar problems!
Best regards,
