How I Handle Frequent Power Outages in Florida with Aqara + Homebridge
Living in Florida means dealing with frequent power outages—especially during heavy rain or hurricane season. Over time, I’ve built a system that keeps my smart home stable and consistent even when the power flickers. I wanted to share my setup in case it helps others in similar situations.
The Core Setup
IMG_1756
• Aqara M100 Hub – plugged directly into an outlet (so when the power goes out, the hub goes out too).
IMG_1757
• Homebridge (running on a server connected to a UPS) – keeps running even when the main power drops.
• Homebridge Plugins Used:
• Ping Hosts – constantly pings my Aqara M100 Hub.
• Delay Switch – lets me insert a timed buffer before automations run.
How It Works
  1. Normal Operation:
As long as the Aqara M100 Hub is online and powered, the Ping Hosts plugin gets a positive response.
  1. Detecting an Outage:
If the power goes out, the hub loses power, and Ping Hosts starts reporting negative results. Since my Homebridge server is on a UPS, it continues monitoring.
  1. The 5-Minute Delay:
I use Controller for HomeKit to create an automation that waits 5 minutes after a negative ping is detected. This buffer ensures I don’t get false triggers from quick flickers and gives all devices time to reconnect when power returns.
  1. Confirming Recovery:
If a positive ping is detected after the 5-minute delay, that’s my reliable indicator that power went out and has now come back.
  1. Post-Recovery Automations:
At this point, I have automations that:
• Turn off devices that default to “on” after power is restored but shouldn’t be.
• Turn on devices that lost power and didn’t automatically recover.
This way, my smart home essentially “resets” itself to the correct state after every outage, without me needing to intervene.
Why This Helps
Florida outages can be short or long, and the biggest headache is devices ending up in the wrong state afterward. This combination of the Aqara Hub, Homebridge Ping, and a smart recovery automation has made my setup resilient and hands-off.
Hi @US-EddieDaYankee , Thanks for sharing, this will be useful for users with power outages.
That’s an amazing setup sharing. Thanks for sharing such a useful solution for power-outage issues. Hope it helps many!
Excellent, thank you for sharing !
Thanks for sharing, a simple idea I wish I had thought of. Just need to build a snazzy status dashboard. Im going to adopt this for Home Assistant!
Regards
Paul
Once Aqara introduces their wall screen/tablet, I hope to get into some wall dashboards.
Hello, I also have a problem with an unstable industrial network in Ukraine. I use a leak sensor to signal a quality network (there is an electrical network or not) to turn off the light, turn on the heating, On/Off emergency lighting (12-24 volts). I opened this topic in my description, maybe you will need it too. Alternative use of the Aqara leak detector
