Hi everyone,
I’ve been really diving into optimizing my smart home setup lately, and I wanted to share my journey with optimizing my pool pump energy usage using Amber Electric’s Forecast feature. I’ve always been interested in energy efficiency, but I never thought I’d get this deep into the details!
So, here’s the background: I’ve got a pool, and maintaining it requires running the pump and heater for several hours a day. The challenge was figuring out the most cost-effective times to run these devices. I stumbled upon Amber Electric’s Forecast feature, which provides hourly electricity price predictions, and I thought, why not use this to my advantage?
I started by setting up my pool automation system with AstralPool’s Connect10. It already had some basic triggers, but I wanted to take it to the next level. My goal was to run the pool pump for 8 hours a day during the cheapest times and adjust the heater runtime based on the temperature gain needed. The logic was there, but the implementation was a bit tricky, especially since I’m still new to programming and home automation.
I began by analyzing the Amber Electric Forecast data. The idea was to identify the cheapest 8-hour window each day for the pump and then schedule the heater to run during those same hours. But there was a catch: the heater’s runtime depends on the time of year and whether the pool cover was left off overnight. I needed a way to dynamically adjust the heater’s runtime based on the temperature gain required.
After some research, I found that I could use the historical temperature data from the pool sensor to calculate the average temperature gain per hour. This allowed me to estimate how long the heater needed to run to reach the desired temperature. It was a bit of a math puzzle, but it started to come together!
The next step was integrating this logic into my home automation system. I used a combination of sensors, triggers, and conditional statements to automate the entire process. It took a lot of trial and error, but I eventually got it working. The system now dynamically selects the cheapest hours based on the Amber Electric Forecast and adjusts the heater runtime accordingly.
One thing I learned along the way is the importance of logging and monitoring. I set up detailed logs to track the system’s performance, which helped me identify and fix issues quickly. It was frustrating at times, especially when things didn’t work as expected, but it was incredibly rewarding to see everything come together.
I’d love to hear from others who have tackled similar projects. How do you optimize your energy usage? Have you used Amber Electric’s Forecast or other tools to reduce costs? I’m always looking for new ideas and tips to improve my setup!
Thanks for reading, and happy automating!
Best regards,
