Hi all, I wanted to share my experience integrating multiple smart devices using SmartThings. I’ve been using SmartThings for a while now, and it’s been a great journey. I have a mix of devices from different brands, and I wanted to share how I managed to get everything working smoothly together.First, I started with the basics—controlling my lights and other essentials. It was a smooth setup, and I quickly got the hang of using Action Tiles on my Amazon tablets. But I wanted to take it further. I have a fireplace with an IR blaster, and I wanted to be able to control the colors. After some research, I found that integrating it with SmartThings wasn’t too bad. I used SwitchBot’s IR blaster, which worked well on my phone, but I had trouble linking it to Alexa or my tablets. I had to dig into the settings a bit, but eventually, I got it working!Next, I wanted to add my ceiling fans. They were a bit tricky because they’re from an unknown brand, but I managed to link them using the same SwitchBot setup. It was a bit of trial and error, but I got there in the end. I also wanted to control my amplifier, which was a bit of a challenge, but I found a way to map the channels through the app.One thing I learned is that patience is key. Sometimes, devices don’t work as expected, but with a bit of tweaking and research, you can usually find a solution. I also found that using the right accessories, like the SwitchBot IR blaster, made a big difference.Now, everything works seamlessly. I can control my fireplace, fans, and amplifier from my tablets or Alexa. It’s been a great setup, and I’m really happy with how it all came together. I hope this helps someone else who’s trying to integrate multiple devices. If you have any questions or tips, I’d love to hear them!
