I’m finding certain things a bit lacking, some things are not exposed. This is using the USB hub plugging into Home Assistant.
I’m yet to see the real benefit. Looking to upgrade this year though with uk specific devices now being available
I’ve noticed that with some Matter devices too. The basic controls work, but some device specific features don’t seem to be available through Matter. I think it depends on what the manufacturer has included in its Matter support.
No problems here, i have my U200 door lock paired with the matter hub which is then linked to home assistant via the network.
I have been happy with the HA matter implementation. As I’ve added more thread devices things have improved in the sense of connectivity. Light bulbs are nice thread repeaters.
Edit to add: I have not needed the properties that aren’t passed via matter - yet, anyway. The important stuff for my needs have been met. And it’s only going to get better.
I am quite happy with it so fare, I do use it both ways, I can bind Aqara products to HA but I also use it to bind HA devices / helpers to the Aqara app.
I mostly use it for my G410 doorbell and my TRV, they are a bit old but rock solid with the matter pairing (better than zigbee directly to HA in my opinion)
I came on here looking for whether Matter supports illumination on the Motion Sensor P1 and Atmospheric Pressure on the Temperature and Humidity Sensor T1. Both parameters work on the Aqara Home app but don’t seem to be exposed to Home Assistant. Am I missing something?
So far my biggest issue is with the UK H2 Outlets. In Matter it reports power usage, but at an overall device level, not at each socket which is a pain in Home Assistant, and useless in Apple Home.
When I set them up as Zigbee, so each socket is reported in the Aqara Hub M3 and exported them as Matter devices, it then did not show any power information via Matter even though it did at a Zigbee level on the M3.
Welcome to the forum, @stevegreenham !!!
Of what exactly?
Between the Aqara app and Hub with Home Assistant or the products (FP300, FP400, etc) directly to HA?
I know things are lacking because Matter doesn’t support everything (yet) that Aqara has available in their app.
But other than that I’m happy with the integration of the products.
I buy things based on what the device can do in Home Assistant now rather than what it’s marketed to do when you are integrated in the Aqara eco system.
@stevegreenham — you’re not missing a setting, as far as I can tell. This looks like a limitation of how the bridge exposes those sensors over Matter, rather than a Home Assistant problem.
The Motion Sensor P1 is a Zigbee device, and when it’s bridged to Home Assistant via Matter the hub has to map each capability to a Matter device type or cluster. Motion/occupancy maps cleanly, but illuminance is a separate Matter device type, and Aqara’s bridge doesn’t seem to expose the P1’s light sensor as a separate endpoint — so Home Assistant only sees the motion part.
It’s a similar story with the Temperature and Humidity Sensor T1: temperature and humidity are standard Matter clusters and come through, but atmospheric pressure uses the Pressure Measurement cluster, which Aqara doesn’t appear to map for that sensor over its Matter bridge. That’s why it shows up in the Aqara Home app, where the native Zigbee data is available, but not in Home Assistant over Matter.
A couple of things worth checking:
- On the device page in Home Assistant, check whether there’s a disabled entity for illuminance or pressure — sometimes they’re created but disabled by default.
- Make sure the hub firmware is up to date, as Aqara has added Matter exposures for some sensors over time.
- If you need those readings in Home Assistant, the usual workaround is to connect the sensor directly to Home Assistant over Zigbee, for example with a Zigbee coordinator and ZHA or Zigbee2MQTT, where the illuminance and pressure clusters are exposed directly — though that means losing the Aqara hub as the bridge for that device.
So in short: it’s expected behaviour for the current Matter bridge, not a misconfiguration on your side.
