Hey everyone, I just wanted to share something I figured out recently that I think might be helpful for others. I’ve been working on setting up some automation rules in my smart home, and one thing I really wanted was the ability to stop a running rule with the press of a button. For example, if I have a rule that turns on lights, waits a minute, then opens a door, I want to be able to hit a button and immediately halt that process if needed.
At first, I wasn’t sure if this was even possible. I did some digging in the forums and found a few hints, but nothing that gave a clear step-by-step guide. After some trial and error, I finally got it working! Here’s how I did it:
- Identify the Rule ID: Every rule in your system has a unique ID. You can find this in your automation settings or logs.
- Create a Button Trigger: Set up a button (either physical or virtual) that will trigger the stop action.
- Use the Rule Stop Command: In the automation app, there’s usually a command or service that allows you to stop a rule by its ID. I used the
rule.stopservice and passed the rule ID as a parameter. - Test It Out: I created a simple test rule that turns on a light and waits 30 seconds before turning it off. I set up the stop button and tested it at different stages to make sure it worked.
It’s been a game-changer for me, especially for longer sequences where I might want to pause or cancel midway. I hope this helps someone else out there who’s trying to add that extra layer of control to their smart home setup! ![]()
