Hi, please be kind, I’m a newbie here and feeling daft. How do you go about changing the AA batteries on the G4 doorbell without the siren going off? Is there a setting or switch or something I’m missing?
@kmallen10 Hello and welcome! No need to feel daft; we all start somewhere, and it’s great that you’re reaching out for help.
To change the AA batteries on your Smart Video Doorbell G4 without triggering the siren, it’s essential to follow some key steps. First, ensure you have a Phillips (cross-point) screwdriver, which you’ll use to loosen the holding screws on the back plate. This is part of the battery power-up process, as detailed in the installation procedure. After loosening the screws, gently slide the back plate down to remove it.
The reference information doesn’t specifically mention a setting to disable the siren during battery replacement. However, it might be helpful to try temporarily disabling any tamper alarm settings if available in your app or settings, or ensure the doorbell isn’t connected to the network during the battery change to prevent alerts.
If anyone in the community has additional insights or tips, feel free to share! We’re all here to help each other out.
The only way I have found is to disable Tamper Detection before you do anything else.
Device Settings → Detection Settings → Tamper Detection
Thank you both so much! I didn’t realise it was a separate setting.
