Hey everyone, I’ve been diving into the world of smart home automation lately, and I thought I’d share a fun project I recently completed. I’ve managed to set up my IKEA Tradfri wireless dimmer to control my smart blinds (Somfy), and I’m absolutely thrilled with how it turned out! ![]()
Why I Did It
I’ve always loved the sleek design of IKEA’s Tradfri dimmers, and I wanted to find a way to integrate them into my existing smart home setup. My smart blinds were a perfect candidate for this project since they’re already connected to my Home Assistant system. The goal was to use the dimmer to control the blinds’ opening and closing, just like I’d use it to adjust a light’s brightness.
The Process
I started by researching how to pair the Tradfri dimmer with my Home Assistant setup. After some digging, I found that using deConz and Node-RED was the way to go. Here’s a quick rundown of the steps I took:
Setting Up deConz
- I installed deConz on my Raspberry Pi to handle the Zigbee communication.
- I paired the Tradfri dimmer with deConz, which was straightforward once I figured out the right sequence of button presses.
Configuring Node-RED
- I set up a Node-RED flow to listen for events from the Tradfri dimmer.
- I mapped the dimmer’s slider movements to commands that would adjust the blinds’ position. For example, sliding the dimmer to the middle position would partially open the blinds, while sliding it all the way up would fully open them.
Testing and Fine-Tuning
- I tested the setup extensively to ensure smooth operation. It took a bit of tweaking to get the sensitivity just right, but once it was dialed in, it worked like a charm!
The Result
Now, I can walk into my room, give the Tradfri dimmer a quick flick, and watch as my blinds respond perfectly to my command. It’s such a satisfying feeling to have this level of control over my home environment!
Why It’s Useful
This setup isn’t just about convenience. By using a dimmer that’s already part of my home decor, I’ve managed to create a seamless integration that doesn’t feel out of place. Plus, it’s a great way to repurpose existing hardware in a new and innovative way.
I’m really happy with how this project turned out, and I can’t wait to tackle my next smart home automation challenge. If you’re looking for a fun and practical way to enhance your smart home setup, I highly recommend giving this a try! Let me know if you have any questions or if you’d like more detailed instructions. ![]()
Cheers,
