How to Create Frames in HABPanel: A Step-by-Step Guide
I’ve been exploring HABPanel lately and wanted to create something similar to the example image I came across. After some digging, I figured out how to create frames that contain multiple items like fans and lights, and even found some cool icons to use! Here’s what I learned:
  1. Frames in HABPanel: Frames are essentially containers where you can group multiple items together. To create a frame, go to the page editor in HABPanel and select the frame widget. You can then add items like switches, sensors, or even other frames inside it.
  2. Adding Multiple Items: To include both a fan and a light in the same frame, simply drag and drop each item into the frame. You can arrange them side by side or stack them vertically. HABPanel allows for a lot of customization in terms of layout.
  3. Icons: For those cool icons, I discovered that HABPanel has a built-in library of icons you can use. You can also import custom icons if you want something specific. Just make sure to format your icons properly so they look good within the frame.
  4. Customization: I played around with the settings and found that you can customize the frame’s background, border, and even add labels. This makes it easy to create a visually appealing interface that matches your home’s decor.
If you’re looking to create a sleek and organized interface for your smart home devices, I highly recommend giving HABPanel’s frame feature a try. It’s been a game-changer for me!
Any tips or tricks you’ve found for using frames in HABPanel? I’d love to hear them!
