Hey everyone! I just wanted to share a quick tip that might help some of you out there. I recently got a Govee watch, and one feature I really wanted to use was the weather display. At first, I was a bit confused about how to get the weather icons to show up properly, but after some fiddling, I figured it out!
So, here’s what I did:
Check the Font Settings: I noticed that the weather icons weren’t showing up because the font wasn’t set correctly. I went into the watch settings and changed the font to ‘Bitmap Default.’ It turns out this font supports the weather icons!
Adjust the Weather Tag: In the text field, I made sure to use the
[WTHR_COND]tag correctly. Sometimes, if the tag isn’t placed properly, the icons won’t display. Double-checking the placement helped me get it right. -
Test Different Fonts: If the icons still don’t show up, try switching between ‘TT’ and ‘Bitmap Default’ fonts. Sometimes, one works better than the other depending on the watch model.
Clear Cache and Reset: If you’re still having issues, try clearing the watch’s cache or performing a soft reset. This can often resolve display-related problems.
It’s such a neat feature once it’s working! The weather icons make checking the forecast so much quicker. Plus, it adds a nice touch to the overall design of the watch face.
If anyone else is having trouble with this, feel free to reach out, and I’ll do my best to help! ![]()
