Hello
I would like to know how it is possible to have two guard and independent systems inside the house I would like that when I am at home a part of the house always remains alarmed.
For example, when I’m at home ,the alarm system it must go from away to present in the house but the garage must remain activated and eventually it must be disabled when I enter the garage not together stop the whole house
I’ve already 2 hubs for the purpose
Interesting idea. Each hub has its own security component, so I guess you could keep one part of the house “Home” and another part “Away”. Seems like kids running around the house (or pets) might cause problems. I guess I feel that as long as I’m home, I can hear what’s going on in the rest of the house. Best of luck on your plans!
Short Answer: Yes but it’s high maintenance
I’ve never needed two independent systems for that purpose but I do have two independent systems that can accomplish what you described.
I built them so I had a backup security system.
I use Home Assistant with a Alarmo integration and purchased a Siren off Amazon.
My primary security system uses Aqara products with Apple Home
My secondary security system uses Home Assistant with indepedant devices.
You can do the same with one Aqara or Apple Home system also but you will need to isolate the different area(s).
It’s overkill and you can use both at once or one at a time or neither. It’s simple and works.
You mean isolate the 2 areas creating 2 homes?
I want to manage with apple home and aqarahome as well but i need two separate state.
Now in aqara home guard i have only one control for both.
In apple home 2 single system security but status change is the same for both
Yes, in a second home create one area for the second alarm system. It’s going to be clunky (high maintenance) but should work.
