How to Remove the Download Video Tab on Samsung Devices
Hey everyone, I came across an interesting challenge while integrating video.js into one of my projects. I was using it to play videos on Samsung devices, and everything seemed to work smoothly except for one minor issue—the ‘Download Video’ tab kept appearing whenever I played a video. At first, it wasn’t a huge problem, but as I started testing on multiple devices, it became clear that this tab was inconsistent across different models and could potentially disrupt the user experience.
I did some research and found that video.js is known for its flexibility, but sometimes these extra features can be a bit tricky to manage. I tried several approaches, including custom CSS to hide the tab, but that didn’t work consistently across all Samsung browsers. Then, I explored the video.js documentation and discovered that there’s a way to customize the player controls more deeply.
After some trial and error, I found the solution by modifying the player configuration to exclude the download option. It turns out that video.js allows you to specify which controls to show or hide. By adjusting the controls array in the player setup, I was able to completely remove the download tab. This not only improved the user interface but also made the video player more consistent across different devices.
If anyone else is facing a similar issue, I’d recommend checking out the video.js documentation on player controls. It’s a bit technical, but with a little experimentation, you can customize the player to fit your needs perfectly. I’m really happy with how this turned out and hope it helps someone else who’s dealing with the same problem!
