How to Set Up a Smart Irrigation System Based on Weather Forecast
Hi everyone, I’ve been working on setting up a smart irrigation system that turns on or off based on the weather forecast, and I thought I’d share my experience and some tips that might help others who are looking to do something similar.
First, let me explain why I wanted to set this up. I live in an area where water conservation is really important, and I wanted to make sure I wasn’t wasting water by irrigating when it wasn’t needed. So, the idea was to check the weather forecast every morning and decide whether to water the garden based on the expected rainfall and temperature.
I started by researching different weather integrations available in Home Assistant. I tried a few like met.no, OpenWeatherMap, and AccuWeather, but each had its own set of challenges. For example, some didn’t provide the detailed hourly forecast I needed, and others had issues with location accuracy. After some trial and error, I settled on OpenWeatherMap because it offered the most comprehensive data for my needs.
Next, I set up some input booleans to control the irrigation system. I created one for morning watering and another for afternoon watering. The idea was to have these booleans turned on or off based on the weather conditions. For instance, if the forecast predicted more than 3mm of rain in the morning, the morning watering boolean would stay off. Similarly, if the temperature was expected to exceed 30°C, I wanted an extra 30 minutes of watering in the afternoon.
I then created an automation that runs at 4 AM every day. It checks the weather forecast for the next 12 hours. If the rain forecast is less than 3mm between 4:30 AM and noon, it turns on the morning watering boolean. If the temperature is expected to be above 30°C at any point during the day, it adds an extra 30 minutes to the afternoon watering session.
One of the challenges I faced was getting the exact weather data I needed. The weather integrations provide a lot of information, but sometimes it’s not perfectly aligned with what you need for an automation. I had to do some tweaking with the data processing to make sure I was getting the right values for rainfall and temperature.
Another thing I learned was the importance of testing. I set up the automation with some debug logs to track what was happening each day. This helped me catch any issues early on and make adjustments as needed. For example, I realized that the rain forecast data wasn’t always accurate, so I added a buffer to account for any discrepancies.
After a few weeks of tweaking and testing, the system is now working really well. It’s great to see the irrigation system turning on and off based on the weather conditions without any manual intervention. It’s saved me a lot of water and time, and it’s been a fun project to work on.
If anyone else is looking to set up something similar, I’d recommend starting with a simple automation and gradually adding more features. Also, don’t be afraid to experiment and adjust things based on your specific needs and the weather patterns in your area. Happy automating!
