How to Start the Best Smart Homes (Aqara + Apple Beginner Guide)
:round_pushpin: Intro
Ever wondered how to build a smart home that just works — reliably, securely, and without needing a degree in tech?
Welcome! In this guide, I’ll show you step by step how to set up one of the best smart home systems available today.
We’ll be using a combination of the Aqara Home and Apple Home apps, & Aqara devices.
This guide is perfect if you’re completely new to smart homes — or even new to tech.
By the end, you’ll have a reliable, secure, and expandable system ready to grow with you.
:brick: Chapter 1: Start with Your Own Router (Not ISP Provided)
ISP routers are usually weak: they have fewer security features, limited parental controls, no advanced Wi-Fi options, and poor long-term stability.
Buying your own router gives you better performance, stronger security, and full control.
Think of it as a little cost now that saves you big tech headaches later, or “Buy once, cry once”.
:top: Some Good Smart Home Routers:
Here are 5 of my top picks for a good router to use as the backbone of your system.
The first one is the one I use personally.
  • Asus ZenWiFi Pro ET12 (Wi-Fi 6E Mesh) – With strong tri-band mesh. Start with one unit, expand to two or more.
  • Amazon Eero Pro 6E – great for ease of use, stable mesh, integrates with Alexa.
  • Netgear Orbi RBKE963 – premium option with Wi-Fi 6E, huge coverage.
  • UniFi Dream Router – more advanced, great if you want pro-level networking.
  • TP-Link Deco XE75 – budget-friendly Wi-Fi 6E mesh with solid performance.
:wrench: Chapter 1a: Setting Up the Router
  1. First, switch your ISP router to modem mode — this disables its Wi-Fi and routing features. Instructions can usually be found on your ISP website or on Google. It usually involves going to a web browser and typing in 192.168.0.1 and entering the username and password usually printed on the rear, or under side of the router. In the settings there will be a setting to change the router to modem mode.Mote that to log back into the, now, modem, you will now have to type 192.168.50.1 usually if you ever want to return the ISP router to router mode.
  2. Connect your new router to the ISP box using Ethernet — usually the WAN port.
  3. Use the router’s app or web setup page to finish configuration. Again, if done through a web interface, this will be done by typing in 192.168.0.1 and following the prompts.
  4. Important: Create separate SSIDs (network names) for 2.4GHz, 5GHz and 6GHz if you have a riBand router.
  5. Optionally, and highly recommended you can add a PoE (Power over Ethernet) switch to power hubs and cameras more cleanly and reliably.
:apple: Chapter 2: Anchor with an Apple Hub
Now we’re going to start adding the hubs you need to make everything run smoothly and efficiently.
We’ll start with the Apple TV and move on to the Aqara M3 in the next part.
  • If you don’t already have one, set up an Apple ID. This will sync your Home app across your devices.
  • The best main hub is the latest Apple TV 4K (with Ethernet) — it handles automations, remote access, and works quietly in the background. It has the benefit of being a streaming box and has support for Thread.
  • Bonus: Adding a HomePod or HomePod mini gives you extra range and doubles as a speaker. Additionally, you can buy two HomePods or HomePod minis and use them as surround speakers for your TV.
:brain: Chapter 3: Add the Aqara Hub
Let’s set up the Aqara hub.
The steps may vary slightly between models — but the essentials are the same, and you can follow along either way.
  • First, download the Aqara Home app and create an account if you don’t already have one.
:wrench: The Hub M3 is the most powerful. It has:
  • Power over Ethernet
  • Dual-band Wi-Fi
  • Zigbee, Thread, IR, Matter bridge capabilities
  • Built-in speaker for alerts
Let’s walk through setting up the M3 step-by-step.
  • If you’ve added a PoE switch, plug the M3 into that using an Ethernet cable — this gives you the most stable connection and powers the hub at the same time.
  • If you don’t have PoE, no problem — just use a USB-C power adapter to plug it in.
  • Open the Aqara app and tap the “+” button in the top right of the app to add a new device.
  • In most cases, the M3 will pop up automatically using Magic Pair.
  • If not, scroll through the device list and select Hub M3 manually.
During setup, the app will ask whether you want to add the hub using Matter or HomeKit.
For this guide, we’re going to skip Matter setup for now and go with HomeKit only.
That’s because we’ll be pairing all devices in the Aqara app first, and then linking them to Apple Home using the 3-dots menu later — it’s more stable this way, and gives you better control.
:toolbox: Other Aqara Hubs you can also use:
  • Hub M2 – Ethernet/Wi-Fi, IR controller, Zigbee, Matter → a solid mid-tier option.
  • Hub E1 – Compact, USB-A powered, Zigbee 3.0, and HomeKit compatible → great as a secondary hub.
  • Hub M100 – Wi-Fi 6, Zigbee + Thread, Matter-ready → ideal for smaller setups.
  • G2H Pro, G3, G5 Pro Camera Hubs → Great choices as you get a hub and a camera all rolled into one!
  • G410 Doorbell → ideal for security, is a doorbell and camera, a hub and feature rich.
  • Pannel Hub S1 Plus → Luxury at its finest. ZigBee, WiFi, 3 wired relays, acts as a doorbell/camera viewer, wireless buttons control and all in a 6.9” display.
:house: HomeKit Mode vs. Standard Mode
  • Add devices first in the Aqara app. This gives you better pairing stability.
  • Once added → go to device settings → tap “Add to Apple Home.”
  • This lets Aqara handle firmware and pairing, while Apple Home gives you a clean daily interface.
  • HomeKit Mode” means the hub talks directly with Apple — but I have found pairing through Aqara first is more reliable in practice.
:electric_plug: Chapter 4: Add Your Devices
  1. In the Aqara app, tap “+” and use Magic Pair to auto-detect.
  2. If that doesn’t work, pick from the list, scan a QR code, or follow the on-screen steps.
  3. After pairing, open the device settings → tap “Add to Apple Home.”
:bulb: I recommend starting with a door/window sensor and a smart bulb — it’s simple and gives you an instant automation to try with a sense of achievement when set up.
:white_check_mark: Good Starter Devices:
  • Lighting: T1M Ceiling Light, T2 Bulb, T1 Light Strip
  • Cameras: G5 Pro (outdoor PoE), G3 (indoor with AI)
  • Sensors: FP1E Presence, Water Leak Sensor
  • Lock: U200+ Smart Lock (supports Apple Home Keys)
You don’t need to buy everything at once.
Start with one or two simple devices, get comfortable, and build from there.
:gear: Chapter 5: Automations
Let’s create your first automation together.
I’ll walk you through it step by step.
  1. First, add a T2 bulb (or any smart light).
  2. Then add a door and window sensor
  3. Now we’ll build the automation:
  4. Open the Aqara app.
  5. Tap “Automation” at the bottom or go through the device’s settings.
  6. Tap the “+” at the top right of the app.
  7. Under the “WHEN” section, tap “Add Trigger”
  8. Tap “accessories”, find the Door/Window sensor, tap it and select “Opened”
  9. Under the “then” section, tap “add Action”
  10. Tap “accessories”, find the light, tap it, then select “turn On”
  11. Tap save at the top right. Either keep the name given, or rename it as desired. Hit save again and thats all set up.
If the light is in a cupboard, you can repeat these steps for a second automation changing the sensor to “When Closed” and the light to “Turn Off”. This way when the door is open, the light will be off, and vice versa. Handy if someone keeps forgetting to turn the light off.
:rocket: Advanced Ideas (Once You’re Comfortable):
  • Use the FP2 sensor to track presence and control lights automatically.
  • Enable face recognition with the G3 camera to unlock doors or trigger custom scenes.
:memo: You can also build automations in the Apple Home app — but Aqara gives you more control at the device level.
:mag: Chapter 6: Why This Setup Excels:
  • Performance: A strong router and PoE network give you a stable foundation.
  • Integration: Aqara M3 bridges Matter, Thread, Zigbee, IR, and Apple Home.
  • Privacy: HomeKit Secure Video keeps your recordings local — no cloud fees.
  • Scalability: Start simple and expand into locks, lights, cameras, sensors, switches, and panels.
:white_check_mark: Last Thoughts:
So now you’ve set up your router, hubs, added your first devices, and created your first smart automation — that’s a solid foundation.
And that’s it! You now have one of the most reliable and secure smart home systems available today.
Start small, expand at your own pace, and soon you’ll be automating things you never thought possible.
If this guide helped, or you have questions, then comment and I will always try to get back to you. Let me know if you’re just starting a smart home, or if you have loads of devices already set up, then share your setup so new users can get some ideas.
Hello, cool description.
I can say one thing, I can hear the creative mood of the author. Thank you. We will also use it as a quick guide for users on the forum.
Thank you, I really appreciate the kind words. Unfortunately, this WAS meant to be my script for a video, however my Tourette’s has been playing up really badly and I had a Tic attack that lasted 2 days and I got really frustrated and upset with myself. So I decided to convert the script into a guide. I just hope it will help someone start their journey into the amazing smart home world.
By the way, in my opinion, in many cases, text instructions are much more useful than videos. You can always return to them (visually) and add your own personal emphasis that interests you.
Good evening to you.
Thank you. Much appreciated :smiling_face_with_three_hearts:
All solid steps and great best practices, it keeps things simple and easy to maintain.
Hi Andy, very thoughtful tutorial! Thank you for noticing the needs of beginners. This must have taken you quite some time.
Thanks for sharing this guide! It’s a great starting point for anyone new to smart homes with Aqara and Apple.
Great tutorial Andy -very good and easy to understand ! Love it Just add the Magic Pad S1 Plus to the hubs please - for me a nice but underrated great hub with lots of joy
About 6 days for the script because I kept having to come back to it, probably would have taken 1 day if I didn’t keep ticking :joy: I just hope it will encourage new users to try their hand at starting a smart home :smiling_face_with_three_hearts:
All updated for you :blush:
Hello, I would appreciate a step by step way to save ban if (window sensor open)!then HUb has an audio chime. I would like to save this and use for each window sensor. Currently I create an automation each time in configure automation with device setup but there is likely an easy way. Also how to her the M3 hub have a speaker would be helpful as the current volume is low at the 100 setting
This is amazing. Wish I found it when I first started building my setup
Thank you for taking the time to write all of that up. It’s greatly appreciated! I’m new to the Internet things and smart and I have chosen Aqara and Homey.as I didn’t think Home Assistant was in my wheel house.
Although I’ve had some issues with my G4, smart doorbell and my Akara hub GH2 pro being hacked! I’m curious as to what extra security precautions are necessary other than setting up the lanes, but how to do to end encryption so only the devices that I have selected can actually communicate with those hubs, is that even possible ?
Hi there.how exactly do you know that you were hacked?the only security you need is to not use the ISP router use one that Andy mention as this routers have great security also add an strong password for your WiFi.more important do not access web pages that you do not know or access links from emails that also you do not know because there are a lot of scam emails with links inside that could infect your devices once you access it.i receive a lot of emails telling me that my account was blocked or that I need to recover my pass on Amazon for example all this type of emails are scams.
Hey Andy.nice guide.i would also mention WiFi 7 routers like HUAWEI B3 witch I currently use and does the job perfectly sure I had to make some adjustments so my Apple devices can communicate well.since ios26 I got many times per day “network issue” in Apple home app and I know that Apple home app is not perfect but now after all the setups I did on my router I only get my be 1/2 times per week “network issue” other than that great guide for those that want to start their own smart home.
@UKAndyC . Good script you have there. Largely I agree.
I run Eero Pro 6E. As you probably know, you can’t set up seperate SSID’s for each bandwidth and I’ve never found it to be a problem. That may be down to the routers vendor though.
Depending on your house, you may have to add access points. I live in a Granite House, which is not WiFi friendly, so I have 1 router and 5 access points!
I know this is an Aqara forum, but you can obviously do automations in Apple Home, which can be more multi-vendor - although Matter is changing that. What I like about Aqara is they’ve found a way to enable functions in Aqara to pass through to Apple Home by using Aqara Scenes which can appear as Apple Home Buttons.
I have to point something out: the HUAWEI wifi7 is not so good if you want to use the 160hz bandwidth as after more then 2 weeks of using it has started to change the Chanel from 36 witch I set to 100 directly.i have no idea why and I just got angry an even HUAWEI Spain didn’t help me much so now I bought an Deco x50 instead what an differences.so yeah Andy’s list of routers is the best.
