Have you ever struggled with getting your smart cameras to connect to your home network? I recently faced a similar issue when setting up my new camera at a hotel. The camera kept saying it couldn’t find the network, even though I tried both the hotel’s Wi-Fi and a mobile hotspot. After some research, I found that the issue might be related to network settings or compatibility. I decided to try a few troubleshooting steps, such as resetting the camera to factory settings, checking the Wi-Fi password again, and ensuring that the network wasn’t blocking the camera’s connection. Finally, I discovered that the problem was with the router’s firewall settings. By adjusting the firewall to allow the camera’s IP address, the connection issues were resolved. Now, my camera works perfectly, and I can monitor my space with ease. If you’re having similar issues, here are a few tips: 1. Always check the router’s firewall and make sure it’s not blocking the device. 2. Try resetting the device to factory settings if the issue persists. 3. Ensure that your network is stable and that there are no other devices causing interference. Through this experience, I learned the importance of checking network settings and not assuming it’s always a device issue. Sometimes, it’s just a matter of tweaking the network configuration.
