In order to pair with the Aqara app, I have to switch my account location to China Mainland, however, once my European M100 hub won’t connect with a China based Aqara app (here)
So, is there some other way I can use it somehow?
Hello, and welcome to the forum!
Maybe you can use it via Zigbee2MQTT in Home Assistant.
Depending on which model you have:
Neither of those, apparently, it’s a ZNQBKG41LM
Seems to be supported as well:
Yep, but I wanted to try out the new MARS mode, to keep smart bulb on
Just to clarify: If your main goal is simply to keep the smart bulb on, you don’t strictly need the full “MARS-Tech”.
The standard “Decouple Mode” is designed exactly for that purpose (it separates the button from the relay, so the power stays on). MARS is basically just Decouple Mode plus an extra direct connection/sync.
So, would the standard Decouple Mode be sufficient for your use case?
Right now I have a plain wall switch with a Shelly in detach mode
I wanted to try out the Mars mode and maybe replace the above with just the Z1
