How would you test a solar camera before relying on it through winter?
A member planning cameras in Denmark raised the long, dark winter problem. The public G510/M410 announcement describes a battery camera with a solar panel, but I have no winter runtime data for this kit.
For a trial, I would log daily battery level, event count, recording mode, temperature, and panel shading through consecutive cloudy days, then note any manual charging. If you use a solar camera in a northern winter, what does its worst week look like, and when do you switch to wired power or schedule a recharge? A few sunny days would not establish the margin needed for security coverage.
I’m also really curious to see how it will perform during winter
Whether you use the 24/7 recording feature or HomeKit likely plays a role as well. If either of these features is enabled, the camera’s video feed must be continuously streamed to the station or the Apple Home Hub.
Otherwise, the front of the camera looks just like the G5 Pro, so I’d guess it has a motion or presence sensor that triggers recording or image analysis. If nothing is happening in front of the camera, only the motion sensor is active and consuming power. This means the 10,400 mAh battery should last quite a long time, maybe even months.
Therefore, the battery life will depend heavily on how busy the location is where you install the camera.
That’s probably also the reason why it’s so hard to predict, because it’s actually quite complex. How much does the battery recharge, even when there’s little sunlight? How full was the battery after the summer? How many activities does the camera record on average? Will these assumptions or measurements still hold true in the future?
That’s definitely a problem, but as mentioned before , battery runtime also depends on frequency of the chosen area and Aqara has set different kinds of streaming option / battery saving settings! So it’s definitely interesting, if the new setup can work under bad conditions
All in all, a very interesting subect. And great comments.
Honestly, I see the solar panel as a bonus, to save on the electrical bill, not that I think it consumes a lot, but it’s nice to have. Also, the plus in the solar panel, is not to have any fixed wiring. Maybe one can compare it with a hybrid car.
I’m currently looking at many options, but also, I like to stay in one eco system, so I’m definitely going to wait for the new G510, and for more reviews.
From Barcelona: The opposite situation needs to be tested in the South for this cameras: extra sun and high temperature exposure, and too many complete recharges.
(Sorry for the Northerners, still warm down here).
Haha , I won’t compare it with a hybrid car :joy: if you think about a hybrid car, you have also bad things of both worlds- and that are huge costs in my opinion :grimacing:
I mean, it has bit of both worlds. :sweat_smile:
A constantly full battery can be much worse than complete charges. In addition, a complete charge is not necessarily a full charging cycle.
However, one can certainly intervene more easily on the software side than against a lack of sun :stuck_out_tongue_winking_eye:
To properly test a solar camera before relying on it through winter, summer/autumn performance won’t tell you much. In winter, you face 3 big enemies: short daylight, a very low sun angle, and batteries that refuse to charge below 0°C.
Here is the exact pre-winter test protocol I would run:
Step 1: The 72-Hour “No-Sun” Autonomy Test
Don’t wait for December to find out how long the battery lasts without sun.
  • The Test: Fully charge the camera to 100% via USB, then either disconnect the solar panel or cover it completely with cardboard for 3 consecutive days.
  • What to look for: Monitor the daily battery burn rate. If the camera drops more than 7% to 10% per day under your normal daily motion events, you know the internal battery won’t survive a typical 5-day streak of dark, rainy winter weather without tweaking your settings.
Step 2: The “0°C Charging Cutoff” Reality Check
Most people don’t realize that standard lithium-ion batteries stop charging when ambient temperatures drop below 0°C (32°F) to protect the cells from damage (BMS protection).
  • The Test: On the first frosty morning, check the app: is the solar panel actually delivering charge, or is it idle despite the morning sun?
  • The Takeaway: If you live in an area with freezing daytime temperatures, you must realize the camera is essentially running on pure battery reserves during cold snaps, meaning low-power settings are non-negotiable.
Step 3: Winter Shadow & Steep Tilt Check
The winter sun sits much lower on the horizon than in summer.
  • The Test: Go outside between 11:00 AM and 13:00 PM (peak winter sun). Inspect the panel for “winter shadows” from neighboring roofs, bare tree branches, or eaves that were never an issue during the summer.
  • Adjustment: Adjust the panel tilt to 55°–65° (steep). This directly captures the low sun and prevents snow, ice, and wet leaves from sitting on the panel glass.
Step 4: False-Trigger Stress Test (Cold Air Delta)
PIR sensors are far more sensitive in winter because the temperature difference between a warm object (car engine, person, pet) and freezing air is huge.
  • The Test: Check your 24-hour event log. If wet pavement reflections, blowing rain, or cold drafts cause 50+ wake-ups per night, tighten your AI detection zones immediately. Every unnecessary wake-up drains precious power that the winter sun won’t replenish.
Bottom line: If your camera passes the 3-day simulated overcast drain test with under 10% daily loss and your panel is angled steeply away from winter shadows, you’re 100% ready for winter! :snowflake::sunny:
The no-sun drain test and winter-shadow check are useful ideas. I would treat 7–10% per day, a 0°C charging cutoff, and a 55–65° panel tilt as examples rather than G510 pass/fail thresholds: the public kit announcement does not specify a charging-temperature limit or winter runtime, and panel angle depends on the installation. Comparing measured drain and recharge in the actual recording mode against the site’s likely low-sun stretches would be a stronger test; 72 hours alone cannot guarantee winter readiness.
Good thread - I raised a similar question from Sweden in my own topic. One thing I would add to the logging list is temperature next to charging: lithium batteries generally do not accept a charge below freezing, so up here the panel can have decent daylight and still contribute nothing for weeks if the camera sits below 0C.
Before relying on solar through winter, I would do a baseline week in autumn at the actual mounting spot: log daily battery drain with the real event rate (a busy driveway vs a quiet backyard makes a big difference, as JohnD pointed out). Then December is an extrapolation from measured numbers rather than a guess.
The low sun angle point is also key. A panel that works fine in September can sit in permanent shade in December when the sun barely clears the rooftops.
Great thread and solid advice already. One more angle I’d add to the test plan: failure recovery and connectivity, not just the battery.
  1. Full-depletion recovery: before winter, let the camera run the battery down once (or simulate it by covering the panel for a few days) and see what happens when the sun returns. Some cameras wake up and resume recording on their own; others need a manual restart or even re-pairing after a deep discharge. Much better to discover that in November than in January.
  2. Wi-Fi link at the actual mount: check the signal strength in the app at the mounting spot, then run a couple of live views and event-triggered recordings. A weak link means retransmissions and longer radio-on time, which drains the battery exactly when solar input is weakest. If the link is marginal in autumn, winter won’t improve it.
  3. Panel glass and cable routing: clean the panel before the dark season, and give the cable a drip loop so meltwater can’t run along it into the housing. Quite a few “winter battery failures” turn out to be water getting in through poor cable routing.
why not putting the camera in a fridge? dark and cold for most of the time with fridge opening triggering for camera wake up and recording. :grinning:
Because a fridge probably acts like a Faraday cage and the camera wastes its power trying to contact the base station unnecessarily :rofl:
