Hi, by mistake I made a region change that is blocking my HUB M200 from pairing and go online. Automatic message received warns that it can ask for 3 days to be processed. Unfortunately I can not wait so long because this is blocking very important home automation. Can Aqara support help me in speed up the procedure?
Thank you!
yes please can you escalate this issue ?
@Cemento I totally get the urgency here — having your home automation down for days is frustrating, especially when it was just a simple mistake. Unfortunately, as a fellow community member, I don’t have the ability to escalate or speed up support tickets directly through the forum.
Since AqaraBot has already auto-generated a ticket for you, the fastest path would be to reach out to Aqara’s customer service directly to flag the urgency. You can contact the Aqara Home App Customer Service Team via Profile > Help & Feedback > Customer Service in the app, or scan this QR code:
This will be more efficient. If you do not have an Aqara Home account, please click here to create a ticket.
When you reach out, definitely mention that it’s time-sensitive and blocking critical automations — that context usually helps support prioritize. Hope you get back online quickly
Hello, which region are you referring to? From which region to which region did you make the switch?
I need to revert from China Mainland to Italy.
Product is from Amazon EU. I moved to China Mainland by mistaken during first installation.
Hi @Cemento - unfortunately you need to wait for Aqara support to give the region free again! Don’t know how to force this process
Hi @Cemento
You can contact customer support to have your region changed; please provide a detailed description of the issue in your message. The support email address is: support@aqara.com
thank you, I’ve open tickets and now wrote to this email but so far nobody contacted me… All my automations are now broken, antitheft as well. It’s somehow getting quite urgent.
Please be patient; you will receive a response in the order in which your inquiry was received. Thank you for your understanding.
Thank you for your support. Do you know how will I get notified for region change? Now I’m just trying repairing the hub every now and then
First 24h passed by, hub still locked. Let’s wait.
It’s also weekend for Aqara stuff. I’m sure Monday you get a response
My question: why did you bought that hub witch is not compatible with your region?you should know that Aqara does this because each country have their rules that is why what is for china is just for china and so on.
I bought an EU Hub for EU region.
Then I made by mistake a region change to China Mainland. Now my request is to revert back to EU.
Weird as usually it doesn’t suppose to happen that even if you change region since that hub is for EU aqara app should not let you pair it if the region is for EU.did you try to change back to EU server or your country server and make an factory reset the hub by pressing the power button 10 times?
Here is full sequence I did:
- buy EU for EU
- at first installation make change request by mistake to China
- before being processed I was able to pair and install still on EU region
- evidently, region change happened in background but did not affected the hub
- used HUB on this misaligned way for months (working on EU region but set on China one)
- until yesterday I made a network reset to change from ethernet to Wifi and misalignment reappeared back
- process failed because of region mismatch and asked me to change again to EU, which I made.
- tried hub full reset (10x pressure) but not helped
Hello, have you performed a restart of the entire set—the router, the phone, and the M3 gateway?
One quick follow-up question: did you remove the M3 gateway in the app while set to the China region? If not, you won’t be able to switch to a different region (Europe).
My M200 was in misaligned status, bonded to EU but belonging to China. Before trying a network reset I can see it on EU region. If I switch to China I can’t see any HUB. Anyway, I’ve removed it also from EU but it doesn’t help anyway.
