After an update of the hub M2 to firmware 4.3.8 some of my wireless remote switches react wrong.
I have many versions of the wireless remote switch, single and double rocker. But the versions that only support a single press have problems.
When used in an automation that with a press turns a light on/off it looks like it gives a double signal.
So when the light is off it turns on and immediatly turns off again. Or when the light is on it turn off and immediatly on again.
The switches that support single, double and long press all work fine, so the problem is only with switches that only support a single press.
Anyone have the same problem with the latest firmware of the hub M2 ?
Hello @martinvanderaart
And if you recreate the automation, will the switch behave the same way? Have you tried it?
Yes, i have recreated the automation and the problem is still there.
I also tested 2 automations, one with only a light ON and one with only a light OFF funtion and these work fine. So only the light toggle ON/OFF funtion had the problem.
The problem is with both single rocker and double rocker wireless wall switches that only have a single press option. All others work fine.
