Hub M200 & Door and Windows sensor T1
Hi guys,
not sure this is the right category for this discussion.
I have a quite extended aqara ecosystem based on Hub M200 and several door and window sensor (first gen and T1). Quite all the sensors work well with excellent coverage and no downtime at all. All a part from one that most of the time is marked as signal strenght “excellent” but from time to time drop to weak for some hours and then disappear. I’ve already replaced that sensor with another one but situation is not changing… I guess then it’s an external interference causing that.
Question: which sources of interference in the sorround I may check? Is there a way for changing zigbee channel (it’s fixed on 25). Any other hint?
The signal strength is a red herring, the M100 & M200 always show single strength of 255 for zigbee devices!!
